surge bucking hesitation
80,000 MILES • AUTOMATIC
AHMED AFRIDI
you apply pressure to the accelerator pedal, the engine slowly revs up and when in gear accelerates forward.
Mar 12, 2021 at 4:55 PM
We need to start with testing fuel pressure and vacuum leaks. Here are some guides that will help with this.
To start here is a guide that will cover this issue in general:
https://www.2carpros.com/articles/engine-surges
Then we need to check for vacuum leaks and fuel pressure using these guides when this acts up:
Let me know what questions you have and what you find with this and we can go from there. Thanks
Mar 14, 2021 at 11:31 AM
AHMED AFRIDI
thank you for you kind and early response, can you please tell me what exactly does it cost to make it checked and solution from the workshop in Pakistan Lahore and can you suggest me any good place where i can examine my car properly in Lahore Pakistan? thanks and regards.
Mar 15, 2021 at 1:07 PM
AHMED AFRIDI
this oil is leaking underneath the car.
Mar 15, 2021 at 9:31 PM
Unfortunately we don't have the ability to give estimates or locations on where to get the vehicle serviced. We are located in the USA and without looking at the vehicle it is very difficult to get an accurate estimate on something like this let alone in a different country.
As for the oil leak, we need to start a new post on that issue. That is not going to be related to the hesitation and we need to keep each post to one topic so that others can find the solutions if they have a similar issue and they won't find it under a different topic. Thanks
Mar 17, 2021 at 11:31 AM
