How to clean out coolant charger canister
106,000 MILES
GERALDTERRELL
  • 6 POSTS
I put 50/50 antifreeze in my saving coolant charger canister and I think it uses oil. how to clean it out and add oil?
Supercharger
Aug 15, 2019 at 11:09 AM
I am not familiar with this part (coolant charger canister). Can you maybe take a picture of what you are referring too or do you know another name for it?
Aug 15, 2019 at 11:41 AM
GERALDTERRELL
  • 6 POSTS
S281 Saleen supercharger.
Aug 15, 2019 at 12:45 PM
GERALDTERRELL
  • 6 POSTS
I added 50/50 coolant I think it takes oil.
Aug 15, 2019 at 12:47 PM
Oh. That is certainly different than a 2006 Mustang as it said in the header.
That is your air to water intercooler. This takes coolant. In fact it should be more of an 80/20 mix of water and coolant however, you will not hurt it by using 50/50. You should be good to go. Nice car!
Aug 15, 2019 at 12:59 PM
GERALDTERRELL
  • 6 POSTS
I see white residue around the top and it is oily.
Aug 15, 2019 at 1:19 PM
Okay. Can you get a picture of that as well? Clearly this is normally oil and coolant mixed but the cap is clearly marked inter-cooler and you don't add oil to an inter-cooler. The purpose of the inter-cooler is remove the heat from the air as it enters the engine. Cooler air has a higher density which means more oxygen and more oxygen means more fuel. More fuel means more power.
If you put oil in the inter-cooler it would not remove the heat and it would clog the heat exchanger.
If there is oil in the inter-cooler system, it was either put in there, or you possible have a leak in the engine portion which in theory could allow oil in the system. However, this is a sealed and separate system. See the attached diagram. Have you had to add coolant frequently?
Aug 17, 2019 at 9:16 AM
GERALDTERRELL
  • 6 POSTS
They have oil for the intercooler. I don't know if mines does
Aug 17, 2019 at 10:34 AM
Are you saying that some inter-coolers require oil? I have never seen any of these so that would be a new one on me. Take a look at the attachments. First one explains why there may be some oil in the inter-cooler. Second one is a picture of your cap. This symbol that I circled is a water to air symbol, so it does not take oil.
I am not sure where you are getting the information from that you would put oil in the intercollegiate but to my knowledge this is incorrect.
Aug 17, 2019 at 11:45 AM
