Supercharger not working
72,000 MILES • 3.8L • 6 CYL • TURBO • 2WD • AUTOMATIC
DANOTURBO59
  • 16 POSTS
Can I run the car without the supercharger working?
Sep 1, 2018 at 3:56 AM
Good afternoon.
Yes, you can but you will see a big reduction in engine performance.
What is the issue with the unit?
Sep 1, 2018 at 5:56 AM
DANOTURBO59
  • 16 POSTS
The bottom pulley broke.
Sep 1, 2018 at 6:04 AM
Do you mean on the drive belt on the engine or the pulley on the supercharger?
Sep 1, 2018 at 6:05 AM
DANOTURBO59
  • 16 POSTS
In the supercharger itself.
Sep 1, 2018 at 6:07 AM
DANOTURBO59
  • 16 POSTS
It is too tight for me to get to.
DANOTURBO59
  • 16 POSTS
Any hints for me to help access it? It looks like I will have to remove water pump to access the bolt.
Sep 1, 2018 at 6:11 AM
If it is in the supercharger, you will have to remove it to disassemble it.
Anything in this picture?
Sep 1, 2018 at 6:22 AM
DANOTURBO59
  • 16 POSTS
It is the guide pulley behind the motor mount.
Sep 1, 2018 at 6:27 AM
Can you post a picture for me to view?
Sep 1, 2018 at 6:30 AM
DANOTURBO59
  • 16 POSTS
Hold on.
Sep 1, 2018 at 6:39 AM
Okay, hanging on.
Sep 1, 2018 at 6:40 AM
DANOTURBO59
  • 16 POSTS
Here is best I can get:
Sep 1, 2018 at 6:44 AM
So it is a pulley like the one for the alternator belt?
Sep 1, 2018 at 6:47 AM
DANOTURBO59
  • 16 POSTS
The power steering pump is in the way of the last bolt any comments on removing it with the front wheel drive?
Sep 1, 2018 at 6:48 AM
Is it one of these?
Sep 1, 2018 at 6:49 AM
DANOTURBO59
  • 16 POSTS
No, it is a smooth guide pulley.
Sep 1, 2018 at 6:50 AM
DANOTURBO59
  • 16 POSTS
The pulley is gone it fell apart.
DANOTURBO59
  • 16 POSTS
It is the in right next to the crank on the super charger diagram.
Sep 1, 2018 at 6:52 AM
You will need to drop the power steering pump. There are two 13mm bolts holding the pump to the block. You can access them through the holes in the pulley.
Sep 1, 2018 at 6:53 AM
DANOTURBO59
  • 16 POSTS
Thank you that helps.
Sep 1, 2018 at 6:56 AM
No problem. Always glad to help.
Sep 1, 2018 at 7:02 AM
