Sunroof not working even after motor replacement?
56,000 MILES • TURBO • 4WD • AUTOMATIC
DTLANT6
I just replaced the sunroof motor on the vehicle listed above, now it won’t initialize, and the slide and tilt buttons seem to do random actions. For example, if I do the “slide close” the sunroof tilts open. If I do the tilt close, it slides back but only just barely. When I do the tilt close, it just barely closes stand I have to keep pressing it until I get it all the way shut.
Apr 5, 2023 at 7:07 AM
  • 110,248 POSTS
There is a module that controls this, but they usually are very dependable. Do me a favor, take a look through the initialization procedure below, and let me know if that is what you are doing.
Next, and don't laugh, when you perform the initialization procedure, one of the front doors must remain open throughout the entire procedure.
See pics below
Apr 5, 2023 at 1:05 PM
DTLANT6
Thank you, I will give this a try again. I’ve run through it a handful of times so maybe I just wasn’t holding it long enough. I’ve had the driver side door open each time, so maybe I’ll try with the passenger door open as well.
Apr 5, 2023 at 10:28 PM
  • 110,248 POSTS
Thanks for the update. Let me know how things turn out for you. I'm interested in knowing.
Apr 6, 2023 at 3:14 PM
DTLANT6
I gave this another try and it is still not working unfortunately.
Apr 10, 2023 at 2:44 AM
  • 110,248 POSTS
At this point, we need to scan the can-bus. CAN stands for controller area network. Basically, the different modules are tied together via a few wires. This type of scan will retrieve codes regardless of the module storing them.
Here is a link that shows how it is done:
Let me know if that is something you can do or have done.
joe
Apr 10, 2023 at 1:10 PM
DTLANT6
I do have an OBD2 scanner but not sure if it is the same. I will have to look and see if this is something I can do.
Apr 10, 2023 at 11:59 PM
  • 110,248 POSTS
Let me know if anything shows up for you. If you have a basic scan tool, that is really designed to retrieve powertrain codes. However, anything is possible.
Let me know what you find.
Apr 11, 2023 at 1:23 PM
