Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Toyota
Camry
Body
Sunroof
Close
Sunroof is stuck in tilt position how can I close it manually
2002 TOYOTA CAMRY
165,000 MILES • 4 CYL • 2WD • AUTOMATIC
MITCH SYLVESTER
MEMBER
I have removed the motor. The motor seems to be working okay. Is there a way to manually close it so I don't get rained on?
Jun 10, 2020 at 6:07 AM
Experienced Mechanic
Good afternoon,
If you removed the motor, can you push it down manually?
It should close manually without the motor unless the tracks are seized. Try lubricating the tracks with wd 40.
Jun 10, 2020 at 6:25 AM
Add image or video
Ask a new question
Engine won't start
Check engine light
