Have replaced all four bulbs in both visors, still no light. My Haynes manual covered every interior bulb, but this one. Any troubleshooting ideas?
Sep 2, 2016 at 8:33 AM
HMAC300
✓Experienced Mechanic
it may be the relays in picture behind fuse box inside truck and not sure if these are replaceable or not, but check these if not it will need to be scanned for codes by a mechanic as it may be body module.
Image (Click to enlarge)
Sep 2, 2016 at 9:46 AM
KEVIN POWELL
MEMBER
Thanks so much for the help. That will be my starting option, and i will go from there if the relay is not the culprit. thanks again.
Sep 2, 2016 at 10:44 PM
Please let us know what you find so it will help others.
Best, Ken
Sep 5, 2016 at 3:02 AM
KEVIN POWELL
MEMBER
Found the common ground (black) for both visors was the problem.All 4 visor bulbs are now functioning properly.. Thanks!
Sep 7, 2016 at 7:01 AM
Great to hear, nice find, please use 2CarPros anytime we are here to help.
