Overheated
104,000 MILES • 2.5L • 6 CYL • 2WD • MANUAL
BUMPSIE
Overheated badly and now will not turn over. low on oil and out of coolant.
Jul 19, 2017 at 7:24 AM
STEVE W.
  • 15,413 POSTS
Low oil, and no coolant means you will probably need a replacement engine. When they get that hot the heat damages parts like the bearings and rings as well as warping the head(s) and block. If the rest of the car is in good shape a replacement engine (either a good used one or a re-manufactured one) would not be a bad option if the price is not outrageous.
Jul 19, 2017 at 8:58 AM
BUMPSIE
Steve, thank you for your response. I already thought the engine might well be blown. My question is how I can attempt to revive it. Many years ago I owned a Plymouth Valiant slant six that had overheated and seized, my mechanic poured a small amount of oil down the carburetor and revived it! Any suggestions?
Jul 19, 2017 at 11:21 PM
STEVE W.
  • 15,413 POSTS
Not much like that works on newer engines, they just are not built the way the old vehicles were. Tolerances are much tighter, the blocks and heads are cast with "just enough" material to work, but not enough to survive.
A complete tear down and rebuild is about the only thing that will save the new ones, and even then it can be a challenge depending on what damage occurred.
Jul 20, 2017 at 2:13 AM
BUMPSIE
Thanks again, I appreciate both of your responses.
Jul 20, 2017 at 6:07 AM
  • 55,721 POSTS
Please let us know what happens, we are interested to see what it is.
Cheers, Ken
Jul 21, 2017 at 3:48 AM
