someone put sugar in the gas tank. What can i do to get it out?
May 14, 2016 at 11:33 AM
CARADIODOC
✓Experienced Mechanic
Do not turn the ignition switch on. Doing so will run the fuel pump for a couple of seconds and send the contamination throughout the fuel system. Drop the gas tank and have it steam-cleaned at a radiator repair shop. They may want you to remove the fuel pump assembly yourself.
