It cranks but won't start. Replaced fuel pump and filter, ignition module, MAP 02 sensor, plugs and wires. I'm getting code 43. Electronic spark control. My boyfriend says he replaced it too.
We got it to start but it shuts off when you give it gas. I saw you had the trouble tree for code 43. Could you send me a copy? And should we test/replace knock sensors. Thank you
May 16, 2023 at 8:01 AM
