Service engine soon after smelling gasoline?
81,000 MILES • 4.6L • V8 • 2WD • AUTOMATIC
CFRUSH1
  • 73 POSTS
service engine soon after smelling gasoline. gas gauge seems normal.
Sep 2, 2024 at 3:01 PM
  • 55,851 POSTS
9 times out of 10 it will be one the fuel injectors. I would use a flashlight to inspect each fuel injector and if you find one leaking replace it with the new unit. Here is how the job is done in the images. Check out the images (below). Please upload pictures or videos in your response of any problems so we can see what to help you with. below.
Sep 3, 2024 at 2:05 AM
CFRUSH1
  • 73 POSTS
Thanks Ken.
I have an OBD2 and forscan will the reading work?
Service engine soon light is on steady.
Sep 3, 2024 at 6:32 AM
  • 55,851 POSTS
No, the fuel leak problem means there is a problem with the body of the fuel injector which will not show up in a scan. It must be a visual inspection under the hood.
Sep 3, 2024 at 7:59 AM
CFRUSH1
  • 73 POSTS
Thanks Ken,
I have a mobile mechanic coming by to check it out later. He suggested to not drive it in very hot weather for fire danger.
Sep 4, 2024 at 3:13 AM
  • 55,851 POSTS
Yep, better safe than sorry.
Sep 4, 2024 at 3:35 AM
