sucking noise through throttle body when first started
45,000 MILES • 5.9L • V8 • 2WD • AUTOMATIC
BIG ED$$$$
Hello, so I have a 1974 Dodge D100 custom street truck with a 360 Magnum from a 1995 Dodge Ram 1500, it has headers and a cold air ram intake. After it has been sitting all night and when you first start it there's a loud sucking noise through the throttle body and it will stall the engine a few times, after it warms up the engine runs fine. The throttle body has all new sensors.
Jul 10, 2022 at 7:16 AM
  • 55,682 POSTS
It sounds like the idle air control motor is not working correctly which is common, but we should run the codes in case something comes up, also I have included the IAC motor int he diagrams below so you can check it out. I would clean the motor and passengers first to see what happens.
https://www.2carpros.com/articles/retrieve-trouble-codes-for-chrysler-dodge-plymouth-odb1-1995-and-earlier-car-mini-van-and-light-trucks
Jul 10, 2022 at 11:24 AM
