Stuck in park an no start
200,000 MILES • 6 CYL • 2WD • AUTOMATIC
DAVIDBLANK
  • 8 POSTS
Truck will not start an cannot move shifter from park. The bushing on shifter cable was replaced still not working. What is next to check?
Oct 12, 2018 at 9:07 AM
  • 110,248 POSTS
First, is the engine starter turning the engine in effort to start? Also, I need you to check of the brake lights are working. The park interlock solenoid is powered via the brake light switch. If they are not working, it could be a blown fuse or a bad switch.
Next, I need you to check fuses under the hood in the power distribution box. Check fuses 22, 34 and 36. See attached pictures.
If when you turn the key, nothing happens, I suspect fuse 22. Fuse 22 powers the brake lights and the park/neutral switch. Regardless, check all the ones I mentioned and let me know what you find.
Oct 12, 2018 at 11:34 AM
DAVIDBLANK
  • 8 POSTS
Thank you for the response. I will check them in the morning and let you know.
Oct 12, 2018 at 11:36 AM
DAVIDBLANK
  • 8 POSTS
The engine does not do anything when you turn the key. The dashboard goes off when you try to start the engine.
Oct 12, 2018 at 11:37 AM
  • 110,248 POSTS
Okay. It sounds like one of two things. Either you have a very weak battery or there is a loose or corroded connection at the battery. Read through these links and let me know if it helps.
Also, to test the battery, follow this link.
Oct 12, 2018 at 1:05 PM
DAVIDBLANK
  • 8 POSTS
So far fuse 19 was blown 22 was good and so 34 and 36 . Battery tests fine .
Oct 13, 2018 at 7:21 AM
DAVIDBLANK
  • 8 POSTS
Could it be the ignition switch we had replaced it before?
Oct 13, 2018 at 7:44 AM
DAVIDBLANK
  • 8 POSTS
That is what it was. Thank you for your help.
Oct 13, 2018 at 8:12 AM
  • 110,248 POSTS
Glad to help. Let us know if you have questions in the future.
Oct 13, 2018 at 12:20 PM
