1986 Subaru XT dash lights
1986 SUBARU XT
150,000 MILES • 4 CYL • 4WD • AUTOMATIC
EDJNES
How do you change the dash lights on an 86 xt turbo coup digital dash? Thanks Ed
Mar 12, 2010 at 2:36 AM
DAVE H
  • 13,384 POSTS
Hello .. thanks for the donation .. much appreciated
Removal
Disconnect negative battery cable. Remove steering column bracket bolts and lower column. Remove screws retaining cluster cover. Remove cover after disconnecting wiring connectors.
Remove cluster retaining screws. Pull cluster forward and disconnect wiring and speedometer cable from rear of cluster. Remove cluster.
Installation
To install, reverse removal procedure.
Mar 12, 2010 at 7:33 AM
