1986 Subaru XT 86 subaru xt turbo
100,000 MILES • 4 CYL • 4WD • MANUAL
JESSEWISMANN
I've posted once but did not recieve a response. my car, the subaru xt, has been having engine problems. i would drive about 3 -4 miles then it would start lose power, like i was letting go of the gas and eventually kick back. ive check the coolant temp sensor, changed oil filter, fuel filter. so originally i would turned the car off while it was moving and turn it back on then it was fine, but now the second the car hits normal running temp it does this and the only thing i can do is stop turn it off and let it cool. im confused. is ita temp sensor or ssomething else. ive also changed out the catalytic converter but that did help either. please help me!!! -jesse
Jul 11, 2010 at 3:56 AM
  • 75,988 POSTS
Possibilities: Inspect and test all the following listed below:
Oxygen sensor.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Crankshaft position sensor
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard it.
Jul 11, 2010 at 1:40 PM
