2003 Subaru WRX fuel pump
100,000 MILES • 4 CYL • 4WD • MANUAL
DUENDE
my car wont start, fuel its not been deliver cause it doesnt get to gas filter, i change the fuel pump relay and still wont start, could it be the fuel pump or should i try the fuel pump regulator? so my main question is Where is the fuel pump regulator located?
Aug 14, 2009 at 1:53 AM
BLUELIGHTNIN6
  • 16,542 POSTS
check fuel pressure at fuel rail. if fuel pressure is weak than suspect faulty pump. if fuel pressure is present then replace regulator.
Oct 18, 2009 at 2:43 PM
