2002 Subaru WRX Wont Start
2002 SUBARU WRX
100,000 MILES • 4 CYL • AWD • MANUAL
NOFX_PENNYWISE
My subaru wrx (turbo) was hesitating every once in awhile yesterday when trying to accelerate. Today it will not start.
Dec 28, 2009 at 9:52 AM
Do below to determine whether it's a spark or fuel problem:
Cranks and w/n start
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it
No crank at all/nothing/nada:
Could be the starter, starter relay, park and neutral switch and ignition switch assuming the battery and connections are good.
Dec 28, 2009 at 10:35 AM
