1997 Subaru WRX fitting oil cooler but these oil coming fro
TINTIN2112
Engine Cooling problem
1997 Subaru WRX 4 cyl Four Wheel Drive Manual
hi i have a leak of oil from water pump i notice i was missing oil cooler so bought one but notice should be only water runing through pipes[ i think ][img:98a70aec17]http://www.2carpros.com/forum/automotive_pictures/398411_images_1.jpg[/img:98a70aec17]
why does my car leak oil when warm from this pipe. theres two pipe off water pump but other side the oil leaks out when park the car up are night
Aug 19, 2009 at 8:36 AM
KHLOW2008
  • 41,812 POSTS
Hi tintin2112,
Thank you for the donation.
I am not sure if I am reading your question correctly so correct me if I am wrong.
The 2 pipe joints are water passages and there should not be any oil leaking from them.
If oil is leaking, either the O ring ( red in your picture )is not seated correctly, the internal bolt is not correctly torqued or the oil filter is the cause.
If oil is leaking from water pump, coolant would be contaminated with oil. Is that happening?
Aug 20, 2009 at 5:12 AM
