1993 Subaru Wagon Car Won't Start
1993 SUBARU WAGON
200,000 MILES • 4 CYL • AWD • AUTOMATIC
SUBIEDOO
My 1993 Subaru Legacy wagon won't start. It keeps turning over but won't kick in. What do you think the problem is?
Dave
Mar 15, 2010 at 4:58 AM
Cranks but no start condition:
Fuel and Spark:
Get a helper disconnect a sparkplug wire or 2 and ground it to the engine at least 3/16 away from ground -have helper crank engine over-do you have a snapping blue spark? If so-you have a fuel related problem, check the fuel pressure to rule out the fuel filter/fuel pump/pressure regulator and listen to the injector/s are they pulsing or hook up a noid light. No snapping blue spark continue to troubleshoot the ignition system-power input to the coil/coil packs,coil's resistances,distributor pick-up coil, ignition control module, cam and crank sensors and computer Note: If it doesn't apply disregard it.
Mar 15, 2010 at 12:30 PM
