Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Subaru
Outback
Exterior Light
Running Light
Stay On
2006 Subaru Outback lights don't go out
2006 SUBARU OUTBACK
67,500 MILES • 4 CYL • AWD • AUTOMATIC
PIERSUPPORT
MEMBER
The tail and parking lights stay on when the engine is turned off. What does this mean?
Jul 21, 2009 at 3:53 PM
Experienced Mechanic
Do they shut off with the switch when the engine is off and the key is in the off position?
Jul 21, 2009 at 4:59 PM
PIERSUPPORT
MEMBER
No. The only way to turn them off is to disconnect the battery.
Jul 21, 2009 at 6:25 PM
It sounds like the switch has shorted out internally. Most likely it will need replaced.
Jul 22, 2009 at 4:40 PM
PIERSUPPORT
MEMBER
No, there's a switch on the steering column that I never knew existed. Just turned it off, and voila!
Jul 23, 2009 at 1:26 AM
That will do it. I'm glad you found that.
Jul 23, 2009 at 5:48 AM
DINK24941
MEMBER
I am having this same problem. Where is this switch? Please.
Sep 10, 2009 at 12:41 PM
The switch is located on the bottom section of the steering column. There is a steel rod that runs from the tumbler (key) to the switch.
Sep 10, 2009 at 2:02 PM
DINK24941
MEMBER
Thank you very much. It worked. I just don't understand the purpose of the switch.
Sep 10, 2009 at 11:43 PM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine overheating
