2005 Subaru Outback vibration when starting from a standsti
2005 SUBARU OUTBACK
ROSIEROSENTHAL
Suspension problem
2005 Subaru Outback 4 cyl All Wheel Drive Automatic
Hello. When starting off from a standstill and immediately turning either direction, I feel a vibration. Happens in reverse as well. Had mechanic check it out and after pretty thorough inspection of suspension and wheel bearings, he felt it was the barely legal worn tires that may be the cause, though show no unequal worn areas. Put snow tires on this week and vibration still there.
What could be the cause? Thank you, rosie
Nov 27, 2009 at 2:13 PM
  • 31,937 POSTS
Hi there,
Thank you for the donation,
I would advise to get the transmission checked by a qualified transmission specialist, this maybe a oil pressure related issue in the transmission causing same shudder, best get this check first and if that is ok, re post for further assistance.
mark (mhpautos)
Nov 27, 2009 at 3:33 PM
