2005 Subaru Outback fule filter
60,000 MILES • 4 CYL • 4WD • AUTOMATIC
PAULABF
car is running fine - do I really need to replace the fuel filter which is a big job in the 2005 - part alone is $75.95
Feb 8, 2009 at 8:02 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Fuel filter only needs replaced if you are experiencing trouble with fuel flow and a diagnostic test proves you need it replaced. Replacing your fuel filter is a simple procedure, not hard to perform at all. If you want procedure steps just let me know..
Thanks for using 2CarPros.com!
Feb 8, 2009 at 8:13 AM
