2005 Subaru Outback check engine light
50,000 MILES • 4 CYL • AWD • AUTOMATIC
SUBA1128
In extreme wet weather I have trouble starting my car. The car hesitates and there is a foul smell. Then the check engine llight comes on. The only response I get from subaru dealer machanic is to reset the computer. Why does this happen in extreme wet weather?
Dec 27, 2008 at 2:43 PM
  • 31,937 POSTS
Hi there,
I would be thinking that there is a problem with the weather proofing on a sensor plug, moisture can up set the reading buy causing a hight resistance through the pin connectors, before the codes are cleared you need to get the code ID, this will be a good indication as to which sensor may be at fault.
mark (mhpautos)
Dec 27, 2008 at 2:49 PM
