2003 Subaru Outback OBD2 P0483 code
113,000 MILES • 4 CYL • 4WD • AUTOMATIC
MITCH12
this code came up with OBD2 testing.What is the probable repair to the car ? tHE COOLING SYSTEM SEEMS TO BE WORKING BUT THE CHECK ENGINE LIGHT IS ON.THE RAIDIATOR FANS ARE WORKING.
i NOTICE THAT THE AIR CONDITIONING IS NOT RUNNING COOL AS IF THE FREON IS GONE. THER IS A SMALL SMELL OF BURNING ANTIFREEZE
THE P0483 CODE IS CONNECTED TO THE COOLING FAN. IN THE CODE BOOK.
THANKS
Dec 27, 2009 at 4:56 AM
BLUELIGHTNIN6
  • 16,542 POSTS
DTC P0483 : Cooling Fan Function Problem
If the cooling fan is operating properly than most likely there was a small intermittent failure. Delete the trouble code and if it returns you will need to inspect the cooling fan system (fan and fan motor). If it doesn't return than there was just an intermittent failure at that time.
Dec 27, 2009 at 6:48 AM
