2003 Subaru Outback CV Joint
120,000 MILES • 4 CYL • AWD • MANUAL
RLPRINTER
The Passenger side front CV Joint has a torn boot and had probably been leaking for about a month or so. I do not drive the car very much. Can the boot be replaced or does it make sense to replace the whole CV joint. If so are there any special tools needed? Are there any instructions or advice you can offer if I replace it myself? I used to be a mechanic back in the 1970's
May 25, 2008 at 12:10 PM
BLACKOP555
  • 10,386 POSTS
it is best to replace the whole shaft other than the boot, takes less time and will cost less in the end, plus the whole shaft will be new.
May 25, 2008 at 1:08 PM
