Engine whining noise
2002 SUBARU OUTBACK
AUDREYBABONICH
Noises problem
2002 Subaru Outback 4 cyl All Wheel Drive Manual 170kkm miles
I bought a used Subaru Legacy Outback VDC. It has been a nightmare car so far as I have invested way too much money in repairing it so far. I recently had engine work done as well as a new transmission installed. Engine work comprised of replacing the intake gasket due to low compression on cylinder 6. The car seems to run fine now, however, I am noticing a highpitched whining noise as I drive. It goes up and down as I accelerate and decelerate. It almost sounds like I can hear the engine through my car stereo. Although it is not really loud, I can hear it whether the stereo is on or off.
any ideas?
Apr 9, 2008 at 7:17 AM
  • 55,381 POSTS
Check the serpentine belt to make sure it is not glazed or an accessory bearing is having a problem. Here is a page that will help you get the job done.
https://www.2carpros.com/articles/serpentine-belt-tensioner-replacement
and
https://www.2carpros.com/diagrams/subaru/outback/2002
If all checks you okay what happens is the timing belts were installed without a new tensioner making a whining noise even though everything runs okay it will take out the timing belt soon.
I have included timing belt replacement procedures for you. With diagrams (BELOW)
REMOVAL
TIMING BELT
1) Remove V-belt.
2) Remove crankshaft pulley.
3) Remove belt cover.
4) Remove timing belt guide. (MT vehicle only)
5) If alignment mark (a) and/or arrow mark (which indicates rotation direction) on timing belt fade away, put new marks before removing timing belt as shown in procedures below.
(1) Turn crankshaft using ST. Align mark (a) of sprocket to cylinder block notch (b) and ensure that right side cam sprocket mark (c), cam cap and cylinder head matching surface (d) and/or left side cam sprocket mark (e) and belt cover notch (f) are properly adjusted.
ST 499987500 CRANKSHAFT SOCKET
(2) Using white paint, put alignment and/or arrow marks on timing belts in relation to the crank sprocket and cam sprockets.
Specified data:
Z1: 46.8 tooth length
Z2: 43.7 tooth
6) Remove belt idler (No. 2).
7) Remove belt idler No. 2.
8) Remove timing belt.
BELT IDLER AND AUTOMATIC BELT TENSION ADJUSTER ASSEMBLY
1) Remove belt idler (No. 1).
2) Remove automatic belt tension adjuster assembly.
INSTALLATION
AUTOMATIC BELT TENSION ADJUSTER ASSEMBLY AND BELT IDLER
1) Preparation for installation of automatic belt tension adjuster assembly;
CAUTION:
Always use a vertical type pressing tool to move the adjuster rod down.
Do not use a lateral type vise.
Push adjuster rod vertically.
Be sure to slowly move the adjuster rod down applying a pressure of 294 N (30 kgf, 66 lbs.).
Press-in the push adjuster rod gradually taking more than three minutes.
Do not allow press pressure to exceed 9,807 N (1,000 kgf, 2,205 lbs.).
Press the adjuster rod as far as the end surface of the cylinder. Do not press the adjuster rod into the cylinder. Doing so may damage the cylinder.
Do not release press pressure until stopper pin is completely inserted.
(1) Attach the automatic belt tension adjuster assembly to the vertical pressing tool.
(2) Slowly move the adjuster rod down with a pressure of 294 N (30 kgf, 66 lbs.) until the adjuster rod is aligned with the stopper pin hole in the cylinder.
(3) With a 2 mm (0.08 inch) dia. stopper pin or a 2 mm (0.08 inch) (nominal) dia. hex bar wrench inserted into the stopper pin hole in the cylinder, secure the adjuster rod.
2) Install automatic belt tension adjuster assembly.
Tightening torque: 39 Nm (4.0 kgf-m, 28.9 ft. lbs.)
3) Install belt idler (No. 1).
TIMING BELT
1) Preparation for installation of automatic belt tension adjuster assembly.
2) Installation of timing belt
(1) Turn camshaft sprocket No. 2 using ST1, and turn camshaft sprocket No. 1 using ST2 so that their alignment marks (A) come to top positions.
ST1 499207100 CAMSHAFT SPROCKET WRENCH
(2) While aligning alignment mark (B) on timing belt with marks on sprockets (A), position timing belt properly.
CAUTION: Ensure belt's rotating direction is correct.
3) Install belt idler No. 2.
4) Install belt idler (No. 2).
5) After ensuring that the marks on timing belt and camshaft sprockets are aligned, remove stopper pin from belt tensioner adjuster.
CAUTION: After properly installing timing belt, remove rocker cover and ensure that the valve lash adjuster contains no air.
6) Install timing belt guide. (MT vehicles only)
(1) Temporarily tighten remaining bolts.
(2) Check and adjust clearance between timing belt and timing belt guide by using thickness gauge.
Clearance: 1.0 ±0.5 mm (0.039 ±0.020 inch)
(3) Tighten remaining bolts.
Tightening torque: 9.8 Nm (1.0 kgf-m, 7.2 ft. lbs.)
7) Install belt cover.
8) Install crankshaft pulley.
9) Install V-belt.
INSPECTION
TIMING BELT
1) Check timing belt teeth for breaks, cracks, and wear. If any fault is found, replace belt.
2) Check the condition of back side of belt; if any crack is found, replace belt.
CAUTION:
Be careful not to let oil, grease or coolant contact the belt. Remove quickly and thoroughly if this happens.
Do not bend the belt sharply.
Bending radius: h 60 mm (2.36 inch) or more
AUTOMATIC BELT TENSION ADJUSTERS
1) Visually check oil seals for leaks, and rod ends for abnormal wear or scratches. If necessary, replace faulty parts.
CAUTION: Slight traces of oil at rod's oil seal does not indicate a problem.
2) Check that the adjuster rod does not move when a pressure of 294 N (30 kgf, 66 lbs.) is applied to it. This is to check adjuster rod stiffness.
3) If the adjuster rod is not stiff and moves freely when applying 294 N (30 kgf, 66 lbs.) , check it using the following procedures:
(1) Slowly press the adjuster rod down to the end surface of the cylinder. Repeat this motion 2 or 3 times.
(2) With the adjuster rod moved all the way up, apply a pressure of 294 N (30 kgf, 66 lbs.) to it. Check adjuster rod stiffness.
(3) If the adjuster rod is not stiff and moves down, replace the automatic belt tension adjuster assembly with a new one.
CAUTION:
4) Measure the extension of rod beyond the body. If it is not within specifications, replace with a new one.
Rod extension: H 5.7 ±0.5 mm (0.224 ±0.020 inch)
BELT TENSION PULLEY
1) Check mating surfaces of timing belt and contact point of adjuster rod for abnormal wear or scratches. Replace automatic belt tension adjuster assembly if faulty.
2) Check tension pulley for smooth rotation. Replace if noise or excessive play is noted.
3) Check tension pulley for grease leakage.
BELT IDLER
1) Check belt idler for smooth rotation. Replace if noise or excessive play is noted.
2) Check belt outer contacting surfaces of idler pulley for abnormal wear and scratches.
3) Check belt idler for grease leakage.
Cheers, Ken
Nov 11, 2017 at 3:25 AM
LANCERICHARDSON
My 98 Outback 2.5 engine is making a high pitched sound corresponding to rpms, it comes from front of the engine and sounds almost like small jet engine whine. You can here it from the inside of the car when driving
Nov 11, 2017 at 3:36 AM (Merged)
CJ MEDEVAC
  • 11,004 POSTS
THE DARN SOUND WILL HAVE YOU THINKING IT COULD BE ANYTHING UNDER THE HOOD---SOMETIMES IT'S HARD TO SEGREGATE THE SOUND FROM OTHER STUFF
TAKE A 3-4 FOOT LONG PIECE OF 1/2"-3/4" HEATER OR GARDEN HOSE......SHOVE ONE END IN YOUR EAR....USE THE OTHER LIKE A STETHOSCOPE
WATCH OUT FOR THOSE PESKY MOVING ENGINE PARTS!!!!!
******************I'M SORTA BETTING IT'S YOUR THROTTLE BODY.....THE GASKET IS DOING THE KAZOO THING
REPLACING THE GASKET IS MOST LIKELY YOUR FIX
BE SURE THAT'S THE PROBLEM WITH THE CJ MEDEVAC-0-MATIC STETHOSCOPE
IF NOT, USE IT TO CONTINUE YOUR SEARCH
ANOTHER THING THAT YOU MIGHT CHECK OUT--SHOULD THE "STETH" NOT DO THE TRICK
HOW 'BOUT THIS TEST....IT WILL ELIMINATE EITHER A SERIOUS ENGINE ISSUE OR IT WILL ELIMINATE THE BELT DRIVEN PART
TAKE THE BELT OFF....TURN ALL OF THE PULLEYS BY HAND.....ARE THEY SMOOTH?.....(THE HARMONIC BALANCER IS NOT INCLUDED)
NEXT
WITH THE BELT STILL OFF......FIRE HIM UP.....(NO MORE THAN FOR A MINUTE OR SO!!!! ....AS YOUR WATER PUMP WILL NOT BE CIRCULATING)
ARE WE EXPERIENCING THE SOUND NOW?
THIS WILL ELIMINATE ACCESSORIES----OR MAYBE IT IS NOW MORE OF AN INTERNAL ENGINE NOISE
OK....SHUT HIM DOWN
WHAT HAVE WE DEDUCED FROM THIS....NOISE QUIT? OR IS IT IN THE ENGINE?
YOUR TURN...REPLY BELOW
THE MEDIC
KEEP US POSTED
THE MEDIC
