2002 Subaru Outback timing
80,000 MILES • 6 CYL • AWD • AUTOMATIC
KENNYSCIENTIST
Engine H6 turns over fast but will not start. Suspect timing problem, however could be a sensor. Test with scan shows nothing, no check engine light is on. Do these H6 engines have this problem? Does the front cover have to come off with all those tiny bolts. Subaru appear hopeless to help. This is the 2nd time this has happened in 5,000 mls. Thanks kenny
Oct 25, 2009 at 5:32 AM
CRZYDRVR
  • 432 POSTS
If it cranks over that fast, then it probably has a broken belt. If it is breaking that often, then the person that did the job didn't do something right!
Dec 7, 2009 at 8:57 PM
