2002 Subaru Outback serpentine belt installation or adjusti
91,300 MILES • 6 CYL • AWD • AUTOMATIC
ARECOSPART53
My serpentine belt has come off. How do I reinstall the belt.
Jan 31, 2009 at 4:10 AM
KHLOW2008
  • 41,812 POSTS
Hi arecospart53, Thank you for the donation.
https://images.2carpros.com/forum/automotive_pictures/192750_Serpentine02Outback_1.jpg
Install the belt accordingly leaving the last part to be installed at B = Belt tension adjuster. Use appropriate spanner to turn the adjuster, ( it is spring loaded and you need to turn against the spring) to gain sufficient clearance to install the last part. Replace the belt if the automatic tensioner indicator is out of range.
https://images.2carpros.com/forum/automotive_pictures/192750_Serpentine02Outback01_1.jpg
Jan 31, 2009 at 5:02 AM
