Shakes or Wobbles problem
2002 Subaru Outback 4 cyl All Wheel Drive Automatic 106*** miles
2002 outback 2.5 106***mi. I have been having a misfire problem for 4 months that no one can seem to find out the engine spun a bearing and the entire long block was rebuilt at 102***mi. the misfire hapens under no load during the warm up phase then gets better once warm this happens apx every 3 days I will have somthing replaced hoping to fix the prob have cel reset then it will come back on in apx 3 days always during the warm up phase and the the cel will stay on till next time its reset although one time i drove it for like 10 days with light on and it shut itself off only to reapear in about 2 days the code is always p0304 cyl 4 misfire no other codes the car shakes at idle during warm up and is more noticable when you are stopped with it in drive then once it is warmed up it gets a little smoother here is my long list of expensive repairs that have been perfomed
new: spark plugs 2 different sets
new: wires 2 sets also
new: ignition coil also 2 thought first was defective
new: cyl 4 fuel injector
new: ecu
new: wire harness think the one going to the injectors
new: alternator and battery dealership said output was low at 60amp or volt witchever it is instead of 90
new: airfilter
atleast 4 different compression checks at diferent facilitys all say compression is good and a leak down test also found no leaks
sprayed brake cleaner i think? around intake gaskets vacume lines cant find any vacume leaks intake leaks
dealer said fuel pressure was good new fuel filter
ENGINE RUNS GREAT UNDER ACELERATION NO POWER LOSS NO STUTERING NO BACK FIRE RUNS REAL SMOOTH
THE SECOND YOU LET OFF THE BREAK WILE IN DRIVE THERE IS NO MORE SHAKING EVEN DURING WARM UP WHEN THE SHAKING IS MUCH MORE NOTICABLE
EXHAUST HAS BEEN PRESSURE TESTED AND IS GOOD
WHILE DRIVING AROUND THROUGHOUT THE DAY I SOMETIMES HERE LOUD CLICKS KINDA SOUNDS LIKE A PEN CLICK BUT LOUDER MAYBE A RELAY / FUSE POP
BUT HAVE ALSO TESTED EVERY FUSE AND RELAY AND ALL LIGHT UP
THROTTLE BODY WAS KINDA DIRTY SO CLEANED IT ALONG WITH THE IDLE AIR CONTROL VALVE AND NO DIFFERENT
THIS IS COSTING ME A FORTUNE I HAVE TO FIND THE PROBLEM PLEASE HELP ME WITH SOME IDEAS OF THINGS TO LOOK AT AS MY MECHANIC/S HAVE RAN OUT OF IDEAS SORRY FOR THE VERY LONG POST
new: ecu
new: airfilter
Sep 18, 2008 at 8:23 AM
