2001 Subaru Outback Clutch master cylinder won't charge
GDENNIS
Transmission problem
2001 Subaru Outback 165000 miles
Changed the clutch in my 01 Legacy Outback with no problems. After getting it back together, clutch pedal goes to floor with not resistance. The master cylinder isn't drawing or putting out fluid but it worked perfectly prior to clutch repair, was never opened to the air - slave was only unbolted from trans. Wha happened?
Apr 7, 2009 at 1:00 AM
  • 75,988 POSTS
The clutch master cylinder could be leaking internally -
Apr 7, 2009 at 1:04 AM
