2000 Subaru Outback Hesitation and clunk
2000 SUBARU OUTBACK
35,000 MILES • 6 CYL • 4WD • AUTOMATIC
BUTTERFLYAM
Lately, when I back out, shift into drive, my car hesitates and makes a small clunking sound before engaging into the forward gear. Once it is is, everything is fine and it seems to only do this when I go from reverse to forward.
Apr 2, 2010 at 1:16 PM
CRZYDRVR
  • 432 POSTS
Fig. Fig. 5: Adjusting the brake band
This adjustment can be performed on the outside of the transaxle.
1.Park the car on a level surface or support it on jackstands, engine off.
2.Locate the adjusting screw above the pan on the left side of the transaxle.
3.Loosen the locknut.
4.On 1985 and later models, tighten the adjusting screw to 18 ft. lbs. (25 Nm), then turn it back exactly 3 / 4 turn.
5.Tighten the lock nut.
Following the above procedure will adjust the transaxle brake band to the factory specified setting. However, if any of the following conditions are detected the adjusting screw can be moved 1 / 4 turn in either direction:
Turn 1 / 4 turn clockwise if the transaxle:
Jolts when shifting from 1st to 2nd
Engine speed abruptly rises from 2nd to 3rd, or,
Shift delays in kickdown from 3rd to 2nd.
Turn 1 / 4 turn counterclockwise if:
Car slips from 1st to 2nd, or
There is braking action at shift from 2nd
Apr 3, 2010 at 2:52 AM
