Fuel injectors control
2000 SUBARU OUTBACK
220,000 MILES • 4 CYL • AWD • MANUAL
SUBARU1
Is there anything other that the PCM that will cause the injectors not to open and close to supply gas to cylinder? I have gas to the injectors but not to cylinder. If I put gas into cylinder it will fire. Is there a check to see if PCM is the problem?
Jul 10, 2009 at 1:49 PM
KHLOW2008
  • 41,814 POSTS
Hi subaru1,
Thank you for the donation.
The normal procedure is to confirm if the injectors are getting power supply when cranking. One of the injector wires should have voltage when cranking.
To test if the PCM is grounding the circuit, disconnect an injector wire connector and attach a noid light between the wireharness 2 pins. Crank engine and if noid light pulses, the PCM and circuit is ok.
If not, you would have to test the wire for continuity from injector to PCM.
Jul 11, 2009 at 4:52 AM
SUBARU1
Thanks for the information on how to check the injector. My injectors were good. the problem was fuel pressure. In the fuel pump complete assembly there is a pressure chamber with a metal cap and 0-ring. One the tabs that hold the cap on was split from the manufacture and the system would not build enough pressure for the injectors.
Jul 13, 2009 at 8:34 AM
KHLOW2008
  • 41,814 POSTS
Good that you have solved your problem.
When fuel pressure drops, it would still show it presence at fuel rail and is often mistaken for a no fault situation.
Thank you for using 2carpros.
Jul 13, 2009 at 11:29 AM
AMANDA DAWN BAUERBACH
Hello, we just replace the motor in a 2000 Subaru Outback where does the injector wires go some of them are color coded with green?
Sep 25, 2018 at 3:21 AM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
You have attached a question to a years old question.You need to add your vehicles information and make a new question for you car issue. Here is the link for you to post your question:
Make sure you are logged into the site.
Hope this helps and thanks for using 2CarPros.
Danny-
Sep 25, 2018 at 8:23 AM
