How do I remove the ABS line from the bearing hub assembly?
Aug 15, 2008 at 2:56 PM
SEIZEDBOLTS
MEMBER
[quote:3b82e5bb17="seizedbolts"]Brakes problem
2000 Subaru Outback 4 cyl All Wheel Drive Automatic 115000 miles
How do I remove the ABS line from the bearing hub assembly?[/quote:3b82e5bb17]
Aug 15, 2008 at 3:04 PM
SERVICE WRITER
✓Experienced Mechanic
Remove the bolt, gently twist the sensor clockwise and then counterclockwise until it is moving. Once it is turning do the same motion while pullling. They can seze in there and break taking them out...but not always.
