Login
Join
Ask a Question
Questions by Vehicle
Repair Topics
Testing / Diagnostics
Repair & Service Guides
Symptoms
Warning Lights
Trouble Codes
How It Works
Videos
Login
Become a Member
Home
Subaru
Outback
Steering
2000 Subaru Outback 2000 Subaru Outback Power Steering Issu
2000 SUBARU OUTBACK
245,000 MILES • 4 CYL • AWD • AUTOMATIC
PIPP22
MEMBER
The power steering is out on my 2000 Subaru Outback and the check engine, battery, and brake lights are illuminated.
Any ideas?
Jul 13, 2008 at 4:28 AM
KHLOW2008
Experienced Mechanic
Hi pipp22,
Check if the crankshaft pulley and beltings are ok.
Jul 14, 2008 at 4:20 AM
PIPP22
MEMBER
I hate to ask this, but how exactly would one go about doing that?
Jul 14, 2008 at 5:36 AM
KHLOW2008
Hi pipp22,
On one side of the engine you would see some belts. Start engine and see if they are turning together with the round pulley at bottom.
Hope the belts are still there, if not you have nothing to see.
Turn on AC and see if it blows cold.
Jul 14, 2008 at 5:50 AM
PIPP22
MEMBER
The A/C hasn't blown cold air for quite some time.
I will go check the belts now, though.
Jul 14, 2008 at 6:39 AM
PIPP22
MEMBER
Ah yes. A belt has split and isn't turning.
I assume I simply need to buy a replacement belt and switch them out?
Jul 14, 2008 at 7:25 AM
PIPP22
MEMBER
I thought of a couple additional items while I was away from the computer.
How will I know what belt(s) to buy and how to correctly replace them? Are there any diagrams/etc. online?
Thanks!
Jul 14, 2008 at 7:55 AM
KHLOW2008
hi pipp22, If one belt is bad, the others should be almost gone too, get them all replaced.
For correct size, you need to get the belt part numbers. Ask at the parts outlet, they might be able to assist.
If you are serious about DIY, I would suggest getting a repair manual.
Check out the Car Repair Video Series link to see if there is any on belt replacement.
Jul 14, 2008 at 11:42 PM
🔧 Tools & Auto Repair Parts
Shop on Amazon →
Add image or video
Ask a new question
Engine won't start
Engine overheating
