2000 Subaru Outback
135,000 MILES • 4 CYL • AWD • AUTOMATIC
FROGPOOP
recently had the transmission repaired but still have the smell of trnasmission fluid coming through the vents of the car when it sits idle and the heat is on. the repair was done about a month ago so any fluid that had leaked out has sure to have burned off by now. any suggestions on what else is going on?
Dec 6, 2009 at 11:58 AM
  • 31,937 POSTS
Hi there,
This sounds as if there is still a small leak somewhere, time to take it back to the repairer for them to check this out, they should not be charging you for this either.
mark (mhpautos)
Dec 6, 2009 at 12:24 PM
