1999 Subaru Outback First to second gear
1999 SUBARU OUTBACK
MITCH.MITCHMAN
Engine Mechanical problem
1999 Subaru Outback All Wheel Drive
When I am changing gears from first to second, it often seems that the shift comes out of first gear too easily. It never comes out of gear on it's own, you can just tell that it slides out of first gear a little too easily in comparison to all the other gears. What kind of problem does this sound like? I am guessing clutch, or worse yet transmission, but I don't know.
Feb 3, 2010 at 11:22 AM
2CARPRO JACK
  • 11,533 POSTS
Sounds more like an issue inside the trans than the clutch.Clutch issues are usually related to getting it into the next gear.I wouldnt worry about it if it isnt jumping out of 1st if you hit the gas hard.
Feb 3, 2010 at 12:44 PM
