1999 Subaru Outback CV Axle Removal
1999 SUBARU OUTBACK
EMAGIK609
Engine Mechanical problem
1999 Subaru Outback 4 cyl All Wheel Drive Manual
How do I remove the cv axles from the transmission?
Sep 5, 2008 at 11:14 AM
BLACKOP555
  • 10,386 POSTS
you will have to remove the tire.
then remove the tie rods, strut mounting, ball joints and then pull off the wheel bearing assembly.
next step would be to pry off the cv joint from the shaft using a prybar and a block of wood.
Sep 5, 2008 at 1:43 PM
