1999 Subaru Outback crankshaft pulley
100,000 MILES • 4 CYL • AWD • AUTOMATIC
JDUNDER
the pulley that drives the alternator and A/C belts worked loose and appears to have worn off the key on the shaft. What will be needed to repair this key in order to mount the pulley?
Jul 11, 2008 at 2:23 AM
DOCFIXIT
  • 18,828 POSTS
As long as the keyway was not damaged and no damage to crank snout. Pully , key and new carnk bolt
Jul 11, 2008 at 2:39 AM
