1999 Subaru Outback coolant flow
112,000 MILES • 4 CYL • AWD • MANUAL
KLWORKS
My 99 Legasy Outback has developed an overheating problem. I changed the thermostat and it appears to have the same problem. the upper hose on the passenger side gets very hot. The lower hose coming from the thermostat to the radiator is cold. is there a place within the engine that gets clogged? If so what can I do about it. Also, can the water pump fail in such a way that it does not circulate the water?
Apr 18, 2009 at 4:35 PM
CRZYDRVR
  • 432 POSTS
If it was replaced with an aftermarket t-stat, thats your problem. get a replacement from your dealer. then bleed cooling system. let me know how it works out for you.
Apr 22, 2009 at 6:28 PM
