1998 Subaru Outback turn signal bulb replacement
206,000 MILES • 4 CYL • AWD • AUTOMATIC
BERGYFAN
I can't figure out how to get at the front turn signal bulbs to replace them.
Jul 30, 2009 at 8:40 AM
DANAUTHIER
  • 156 POSTS
The safest (less chance of braking something) is to remove the headlamp assembly. I have the Subaru replacement proceedure below.
Headlight/Turn Signal/Marker Light Assembly
To Remove:
1.Disconnect the battery ground cable.
2.Remove the air duct (right headlight).
3.Disconnect the headlight bulb harness connector. Headlight assembly
4.Remove the 3 mounting bolts and headlight assembly. Remove the light sockets from the headlight housing.
To Install:
1.Insert the light sockets into the headlight housing.
2.Install and secure the headlight assembly with the 3 mounting bolts.
3.Connect the headlight bulb harness connector.
4.Install the air duct (right headlight).
5.Connect the battery ground cable.
Sorry no graffics, having ptoblems importing them.
Dan
Jul 30, 2009 at 9:01 AM
BERGYFAN
There are two mounting bolts on top of the head lamp assembly and there is a screw over to the side holding in the turn signal assembly. Where is the third mounting bolt that holds in the head lamp assembly. the assembly is loose on top after I removed the top bolts but it is still held firmly in place.
Jul 30, 2009 at 10:07 AM
