1998 Subaru Outback piston rod ,pin
1998 SUBARU OUTBACK
130,000 MILES • 4 CYL • AWD • MANUAL
USVICTORY
this car have loud noise and less power.I take two head off,find 1# piston can't come to TDC ,away from about 2.0 mm,and when turn crankshaft,the piston no move with it immediately.Do I need disassembly cylinder block more?how can I do now?
Thank you very much
Dec 25, 2009 at 6:27 PM
It probably jump time -verify the valve timing could be a problem with the T/Belt
Dec 25, 2009 at 6:34 PM
