1998 Subaru Outback 4 cyl Automatic 160000 miles
notice fuel puddling on drive under filler tube elbow. can see gas dripping at bend in tube. why would gas leak from this spot if tank is only half full? how is gas getting to this point if fuel level is low? Will replacing the filler tube remedy the problem or do I need to replace tubes/lines coming off the small tube that is part of the filler assembly?
Jul 21, 2010 at 8:44 AM
