stalls at idle
1998 SUBARU OUTBACK
JUNOBUS
hey,
i recently bought my 1998 legacy outback, it has high mileage but the guy took very good car of it. It drove fine on a test drive and on the way home but i tried to start it 1 hr after getting home and it started and idled for about 4-8 secs and dies, after trying it a few times the battery died, jumped it and it would start but the idle would die. If i give it gas while idling i can get it rev steady above 3000rpm but below that it stutters and stalls, and after starting it a few times it killed the battery again so i bought a new one and it starts but wont idle. The only thing i did before it wouldn't start was replace the air filter, anyone know if theres cables or something around there that if bumped would cause this like the air mass meter or something, someone said it might be the alternator or the throttle body valve?
anyfeedback would be greatly appreciated. thanks
Jun 15, 2008 at 6:26 AM
LEGITIMATE007
  • 5,121 POSTS
yes it could be the mass airflow sensor , located on or near the air filter box, check for any faults /disconected harness etc, you cannot spray anything on it. or it just may need to be replaced, things go bad. also check your idle air control valve. and the breather inside the airfilter box(if it has one).
Jun 15, 2008 at 6:33 AM
STEVIE'S 42
  • 7 POSTS
There is a vacuum leak coming of the hose that connects to the filter housing start at the filter housing follow the bottom the the house that run to the throttle body you will see a nother hose coming out of it an a little probably laying lil under plug it to that should fix mine done the same thing if you'd like I can take a picture for you
Nov 4, 2019 at 5:20 AM
  • 55,423 POSTS
Excellent addition to this thread!
Nov 4, 2019 at 5:34 AM
STEVIE'S 42
  • 7 POSTS
Thank you Ken I appreciate it.
Nov 4, 2019 at 5:36 AM
STEVIE'S 42
  • 7 POSTS
I actually have a question of my own if you don't mind.
  • 55,423 POSTS
Please post your new question here, you must be logged in:
Cheers, Ken
Nov 5, 2019 at 1:49 AM
