1996 Subaru Outback Engine Overheat
200,345 MILES • 4 CYL • AWD • AUTOMATIC
JMPI
Change Water Pump, clean radiator as well as hoses etc.
Fill radiator, start engien, rich normal temperature ; run thge car around the block temperature raise above normal; touch upper hose, is hot; water is coming our form the reseivor tank. open brething air screw air is coming out and no water. Turn off engine water stop coming outr to the reservoir tank.
Please advice
Thank's
Mar 2, 2008 at 1:09 AM
BMRFIXIT
  • 19,053 POSTS
Install new thermostat
fill coolant system and bleed
run car with heat on for about 15 min
shut engine let it cool and then recheck the coolant and adjust
run engine raise RPM add coolant
place cap on
drive and check
Mar 2, 2008 at 3:35 AM
