Change Water Pump, clean radiator as well as hoses etc.
Fill radiator, start engien, rich normal temperature ; run thge car around the block temperature raise above normal; touch upper hose, is hot; water is coming our form the reseivor tank. open brething air screw air is coming out and no water. Turn off engine water stop coming outr to the reservoir tank.
Please advice
Thank's
Please advice
Thank's
Mar 2, 2008 at 1:09 AM
