1996 Subaru Outback
STEVEN BURTON
Heater problem
1996 Subaru Outback 4 cyl All Wheel Drive Automatic
New water pump, new 170 degree thermostat, new radiator, new hoses, slight head gasket leak...temperature still a little above the halfway mark. Is there a 160 degree thermostat I can put in untill I get my head gasket fixed or should I take the thermostat out for the time being? I could imagine that some gases are coming out with every cumbustion causing the coolant to hear up somewhat.
Oct 15, 2008 at 5:43 PM
  • 31,937 POSTS
Hi there,
You can drill a small hole in the thermostat to allow a little more flow to get the temp down a bit more.
Mark (mhpautos)
Oct 15, 2008 at 6:02 PM
