1995 Subaru Outback
JOSEYANDEL
Engine Performance problem
1995 Subaru Outback
WHEN HITTING THE GAS IT SEEMS TO CHOKE. HELP
Jun 11, 2010 at 4:08 PM
  • 75,988 POSTS
Inspect and test all the following listed below:
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard
Jun 11, 2010 at 4:18 PM
