What model is this engine for?
SUBARU
FRECOBOS
Hi guys,
I have a Sandrail dune buddy which has a 4 cil. subaru engine. Now it requires some work on it but the only thing I know about the engine is that it was taken from a Subaru. The number on the engine is EA81 560465 I was told that it was from a 92 vehicle but that is not for sure.
This engine is similar to the old vw beattle engine. It also has adapted a Mitsubishi turbo.
Is there I way to know what model of car used this kind of engine?
That would help me a lot in order to find replacement parts.
Thanks in advance.
Jan 22, 2007 at 5:59 AM
MIKE H R
  • 3,094 POSTS
you say you know it is a subaru engine. from 1990 to 1994 subaru had a 2.2L engine.
Jan 23, 2007 at 12:43 AM
FRECOBOS
[quote:b2aceca1d4="M_J_RITZEL"]you say you know it is a subaru engine. from 1990 to 1994 subaru had a 2.2L engine.[/quote:b2aceca1d4]
Thanks M_J_RITZEL for you reply. This gives me more information about the engine.
Jan 23, 2007 at 2:15 AM
DOJCSANY619
  • 6 POSTS
I did a little checking around, but i couldn't find a 92 model that used the EA81. The latest model I could find was a 87 brat.
Here is a link to the page I found, the top 3 choices used the EA81 and have engine parts available depending on what you need, they might not have everything.
Good luck, I hope this helps. :)
Feb 1, 2007 at 5:43 AM
FRECOBOS
[quote:826e150260="dojcsany619"]I did a little checking around, but i couldn't find a 92 model that used the EA81. The latest model I could find was a 87 brat.
Good luck, I hope this helps. :)[/quote:826e150260]
Thanks dojcsany619 It helps also, I am narrowing the model. So far I think (nor for sure) It is a 1.8L Turbo that probaly was used on the 87 Brat that you mention.
Could you paste the link where you found that information please?
Thanks.
Feb 1, 2007 at 6:16 AM
MIKE H R
  • 3,094 POSTS
subaru ifrom 1979 to 1984 engine was a ea81 it was used in the Brat, DL, GF, and the Gl. the ea 82 was used from 1985 to 1994
Feb 1, 2007 at 9:03 AM
FRECOBOS
[quote:87354d7064="M_J_RITZEL"]subaru ifrom 1979 to 1984 engine was a ea81 it was used in the Brat, DL, GF, and the Gl. the ea 82 was used from 1985 to 1994[/quote:87354d7064]
Thanks M_J_RITZEL and all that replied, I think with this information and the old part I should be able to get the new part.
Feb 1, 2007 at 9:49 AM
MIKE H R
  • 3,094 POSTS
found a web site that has what the engine is, its a engine rebuilding co but at least you can get some more info on that engine it is
jer-us.com/applications/subaru.html
Feb 1, 2007 at 10:18 AM
