transmission going in and out of od 1999 outback
1999 SUBARU
MIKE H R
  • 3,094 POSTS
I just got a used 1999 subaru outback with 116000 miles. when i am going around 30 or more and when i put on the brakes a little the transmission shifts down and when i get back up to speed it does not go into high. i shift from drive to neutral and then back into drive then the car goes into drive
Jan 16, 2007 at 9:22 AM
MIKE H R
  • 3,094 POSTS
If it does not shift right and you just got the car check the condition of the transmission fluid. check if the transmission fluid has a burnt smell. If it does then you should replace the fluid and filter.
Nov 22, 2010 at 11:50 AM
