2001 Subaru Outback No Crank
SUBARU
BES001
I recently purchased a 2001 Subaru Outback 2.5 Liter with 76000 miles. It is from out of state and I wasn't able to personally test drive it. A friend test drove it for me. While test driving he shut the vehicle off and then was unable to get it to even turn over. The passenger was a mechanic and thought to tap the gear shift and it started and ran fine. (We think it might be a neutral stop/safety switch). On the way home from the destination the vehicle killed at a stop light and several minutes later after jiggling and jostling everthing in the vehicle it started. It then drove fine the remainder of the distance to his house roughly 3 hours on interstate. I had sceduled to have another friend finish the relay to my home. The next morning he was in route to the rondevous point when he pulled over to run an errand and found the car again dead. Frustrated for both him and myself I called a tow truck. When the tow truck eventually got there 1 1/2 hours later the vehicle started without problem and he drove it up on his trailer. I have no idea what is causing this because I now have it at my home and have driven it and shut it off and restarted it with no problems. I am afraid it is going to let me down sometime when I need it most. Any idea what may be going on?? Any help will be greatly appreciated.
Thanks,
Ben
Sep 4, 2007 at 9:26 PM
  • 75,988 POSTS
The best method to catch this culprit is while on the act-1st I'll check for fuel pressure and insure its making it to the cylinders-no fuel there-check for power on the injector/s. or an ignition reference signal to the computer that's being use to energize the injector/s.
Everything okay there-disconnect a sparkplug wire and ground it to the engine while cranking her over-do you have spark?
Sep 4, 2007 at 9:39 PM
BES001
That is the problem the it won't turn over to even check spark. It is like the starter relay switch is bad or something.. because when it happens you have power at the ignition all lights go on ect. but you have no crank.
Sep 4, 2007 at 9:44 PM
  • 75,988 POSTS
[quote:69f4df8e16="bes001"]That is the problem the it won't turn over to even check spark. It is like the starter relay switch is bad or something.. because when it happens you have power at the ignition all lights go on ect. but you have no crank.[/quote:69f4df8e16]
Do this find the starter circuit at the solenoid/starter get a test lite turn key to start position do you have power-no power, check below
Lets try the starter interlock relay located behind the left side of dash.
Sep 4, 2007 at 10:18 PM
Suggested Repair
With the key in start, use a test light to check for power at the starter solenoid. If there is no power, inspect the starter interlock relay behind the left side of the dash. Given that tapping the shifter once restored cranking, also check the neutral safety switch.
Conversation Summary
The owner of a 2001 Subaru Outback reported an intermittent no-crank condition: ignition power and lights were present, but the starter did not engage. Tapping the shifter once restored starting, and the car later started after sitting. The expert advised checking for power at the starter solenoid in the start position and testing the starter interlock relay behind the left side of the dash.
