1991 Subaru Legacy Fans Not Working
SUBARU
DEVON MUNKRES
I have a 1991 subaru legacy and the car works and everything but when i start it i can't drive really far because it over heats. I narrowed down the problem to my fans but I can't see why they don't work. Can you please help me ASAP
Sep 21, 2007 at 1:58 PM
  • 75,988 POSTS
[quote:09c090a07c="Devon Munkres"]I have a 1991 subaru legacy and the car works and everything but when i start it i can't drive really far because it over heats. I narrowed down the problem to my fans but I can't see why they don't work. Can you please help me ASAP[/quote:09c090a07c]
If it comes On when you power direct it, than either you have a relay/coolant temperature sensor or a separate temperature switch problem, further could also be the main computer that's failing to energize the relay/s.
Sep 21, 2007 at 2:08 PM
Suggested Repair
If the cooling fans run when powered directly, check the fan relay, coolant temperature sensor or separate temperature switch, and whether the engine computer is energizing the relays.
Conversation Summary
The owner of a 1991 Subaru Legacy says the car overheats because the cooling fans do not work. The expert advises that if the fans run when powered directly, the fault is likely a relay, coolant temperature sensor, temperature switch, or the computer failing to energize the relays.
